Group: DynoMotion Message: 8081 From: yeamans115 Date: 8/9/2013
Subject: well, i am tired of crashing the machine and parts!
so when the ZERO is set why does this magically change when I start the program?
I go to my zero and hit all the 3 axis zero buttons. push start and it quickly changes the green position and rapids to a crashing condition.
there seems to be no rhyme or reason either. it just picks some new cord and runs with that.
if I know where the machine is from the zero and type those cord in the "set" tabs this paces the zero right?
I do nothing with machinecords (red numbers) just work cords (green cords)
I have about 5 years of machining parts on my mills and the kmotion seems to be doing its own thing instead of just running the numbers given.
matt
Group: DynoMotion Message: 8082 From: carlcnc Date: 8/9/2013
Subject: Re: well, i am tired of crashing the machine and parts!
Matt
are you using latest version of kmotion?
I have done approx 20 machines with Kflop
there have been 3 of them that had random comm issues,software lockups and the "lost zero" issue
I found that once I ran a wire from the machine frame to the building ground all those issues were resolved.
I have no idea WHY, because there are many other machines running perfectly without doing this.
ON one machine we had tried different PCs,isolated PC power supplies
usb isolators etc.
even replaced the vfd AND 3phase spindle
but the only thing that solved all the issues was a ground strap to the AC ground buss.
Carl
> matt
Group: DynoMotion Message: 8083 From: Vlad O Date: 8/10/2013
Matt,
Some time problems is simpler then you think.
It is typical problem of grounding issue and could be a leakage inside the one or a few steppers, which is sitting on the machine frame and not properly grounded, or your power supply grounding issue, or like Carl suggest - ground connection to the earth.
It is nothing to do with KFlop or your 5 years of machining, just simple wiring, grounding, etc.
What part of the country you are?
Send pictures of your setup.
Happy KFlopping !
Vlad
matt
Group: DynoMotion Message: 8084 From: TK Date: 8/10/2013
Hi Matt
It could well be a software bug. When Cycle Start is pushed KMotionCNC reads the raw machine position from KFLOP, applies all current fixture, tool, and global offsets and syncs the Interpreter to that starting position.  If this doesn't work correctly it might cause what you describe. But I can't think of how or why it wouldn't work.
It is hard to say for sure but I would expect noise to give a different error.
What Version are you using?  Any clues on when it occurs?  Any special sequence of events?  Offset, Tool, or Fixture changes?  I assume it only happens occasionally?  I don't think you have encoders?  Any post mortem clues?
On Aug 10, 2013, at 3:31 AM, Vlad O <cell.vlad@...> wrote:
Matt,
Happy KFlopping !
Vlad
matt
Group: DynoMotion Message: 8086 From: morgtod Date: 8/11/2013
Matt,
You are probably either calling or clearing fixture offsets at the beginning of your programs. This WILL cause a crash.
Todd
> Hi Matt
> > Matt,
> > Happy KFlopping !
> > Vlad
> >> matt
Group: DynoMotion Message: 8142 From: yeamans115 Date: 8/23/2013
well, it ate up some parts again.
I uploaded my c code here....
http://tech.groups.yahoo.com/group/DynoMotion/files/shizuoka%20cnc/
maybe there is something crazy my dad put in it?
I am running kmotion 43I
mill uses servos motors with gecko drives.
I noticed the servos tick in the middle of the pause after hitting cycle start. kind of like it disables and then re-enables real quick.
the pause after hitting cycle start is the worst feeling ever! it does this once every time you load a g code. after the one time be it a crash or it runs clean there are no more issues.
while crashing this time I hit the Estop button and it did nothing so I hit the stop tab on the kmotion? 2nd worst feeling is the estop not functioning.
I think I am going to start installing some mechanical switch's to make this a safer controller to use.
Group: DynoMotion Message: 8143 From: yeamans115 Date: 8/23/2013
Matt,
Todd
this would make the machine crash every time the g code is run though right?
matt
Group: DynoMotion Message: 8144 From: Tom Kerekes Date: 8/23/2013
Hi Matt,
Not necessarily.  It depends on your overall sequence of events which you are not telling us.  For example if you are assuming there are no fixture offsets (but there currently is maybe due to a previous Job), and then you Zero the stock with the G92 (Zero Button), then if your GCode clears the fixture offset then there will be a huge shift and a crash.  But next time now that the Fixture offset has been cleared it will work ok.
You didn't answer my previous questions.
I guess you miss-typed the Version number.  I assume you meant V4.31i.
You missed uploading one of your C files used called shiz.c
Could you upload your G Code?
What are your Tool Setup | Trajectory Planner Settings?
I'm hard pressed to think of a reason why there would be a delay after loading a file the first time and not the second time like you said in a different Thread.  I'm not denying it - just can think of why.   In both cases it really just runs the file from disk.  Can you give some more clues to help us?  Does the PC completely freeze?  Or does the GCode cursor advance during the delay?  Is everything else (other buttons and such) responsive after loading the file?  Does the size of the G Code file matter?  Is it related to the complexity of the GCode toward the beginning of the file?  (ie many short vectors?)
Sorry for all the questions but we need as much info as possible to narrow down where the problem might be.
Group: DynoMotion Message: 8145 From: Tom Kerekes Date: 8/23/2013
Hi Matt,
Group: DynoMotion Message: 8149 From: yeamans115 Date: 8/23/2013
I will get you some answers...
I don't use any offsets. well, none that I know of. I have 1 zero in the vice and that is all I machine off of.
yes = V4.31i
pc seems to be real stable. there was a tiem that kmotion seemded to stop responding but now it is good.
> Hi Matt,
> From: yeamans115 <yeamans115@...>
> Sent: Friday, August 23, 2013 10:39 AM
> Subject: [DynoMotion] Re: well, i am tired of crashing the machine and parts!
> Matt,
> Todd
> matt
Group: DynoMotion Message: 8167 From: yeamans115 Date: 8/26/2013
ok, here is some hard data for the morning almost crash
just doing some simples engraving
1 zero the 3 axis right where I want it
both machine and part zero the same
2 simulate the run so I know it is all good.
3 cycle start
4 scary long pause and then the zero magically rezero's itself to the last line of the g code! lol
what the hell does that? lol
N5G00G20G17G90G40G49G80
N6m03s3800
g04p4
N7G49
N8T1M06 ( End Mill )
N9G00G43Z0.5H1
N11G94
N12X0.4874Y0.4846Z0.1
N13G01Z-0.005F1.0
N14X0.6125Y0.4846
N15X0.4871Y0.426
N16X0.6125Y0.3677
N17X0.4874Y0.3677
N18G00Z0.01
N19X0.6124Y0.3532
N20G01Z-0.005
N21X0.5377Y0.3055
N22X0.6124Y0.2561
N23G00Z0.01
N24X0.5377Y0.3055
N25G01Z-0.005
N26X0.4873Y0.3055
N27G00Z0.01
N28X0.5441Y0.1052
N29G01Z-0.005
N30X0.5441Y0.0561
N31X0.5082Y0.0562
N32X0.4942Y0.076
N33X0.4885Y0.1086
N34X0.4935Y0.1367
N35X0.506Y0.1539
N36X0.5276Y0.1659
N37X0.5551Y0.1685
N38X0.5808Y0.1635
N39X0.6007Y0.1491
N40X0.6112Y0.1296
N41X0.6139Y0.108
N42X0.607Y0.0798
N43X0.5965Y0.0671
N44X0.5797Y0.0574
N45G00Z0.01
N46X0.6125Y-0.0315
N47G01Z-0.005
N48X0.5341Y-0.0315
N49X0.501Y-0.0407
N50X0.4912Y-0.0547
N51X0.4876Y-0.0771
N52X0.4913Y-0.099
N53X0.5012Y-0.1132
N54X0.5341Y-0.1232
N55X0.6125Y-0.1232
N56G00Z0.01
N57X0.4874Y-0.2107
N58G01Z-0.005
N59X0.6125Y-0.2107
N60X0.4874Y-0.3045
N61X0.6125Y-0.3045
N62G00Z0.01
N63X0.5257Y-0.3921
N64G01Z-0.005
N65X0.5015Y-0.4028
N66X0.4917Y-0.4187
N67X0.487Y-0.4393
N68X0.4951Y-0.4724
N69X0.5187Y-0.4844
N70X0.5392Y-0.4765
N71X0.5487Y-0.4594
N72X0.5591Y-0.4182
N73X0.5756Y-0.3989
N74X0.5971Y-0.4017
N75X0.6086Y-0.4165
N76X0.6121Y-0.4372
N77X0.6108Y-0.4577
N78X0.5995Y-0.4741
N79X0.5798Y-0.4814
N80G00Z0.01
N81X0.45Y0.4926
N82G01Z-0.005
N83X0.45Y0.3815
N84G00Z0.01
N85X0.45Y0.4374
N86G01Z-0.005
N87X0.3249Y0.4374
N88G00Z0.01
N89X0.325Y0.3669
N90G01Z-0.005
N91X0.45Y0.3139
N92X0.325Y0.2611
N93G00Z0.01
N94X0.3683Y0.3485
N95G01Z-0.005
N96X0.3683Y0.2793
N97G00Z0.01
N98X0.451Y0.2465
N99G01Z-0.005
N100X0.3258Y0.2465
N101X0.3258Y0.1677
N102G00Z0.01
N103X0.3254Y0.0571
N104G01Z-0.005
N105X0.3254Y0.1531
N106X0.4505Y0.1531
N107X0.4505Y0.0599
N108G00Z0.01
N109X0.3898Y0.1531
N110G01Z-0.005
N111X0.3898Y0.0656
N112G00Z0.01
N113X0.3249Y0.0425
N114G01Z-0.005
N115X0.45Y0.0425
N116X0.3249Y-0.0513
N117X0.45Y-0.0513
N118G00Z0.01
N119X0.45Y-0.0659
N120G01Z-0.005
N121X0.45Y-0.177
N122G00Z0.01
N123X0.45Y-0.1211
N124G01Z-0.005
N125X0.3249Y-0.1211
N126G00Z0.01
N127X0.4505Y-0.3225
N128G01Z-0.005
N129X0.4459Y-0.2969
N130X0.4337Y-0.2796
N131X0.4137Y-0.2679
N132X0.3884Y-0.2647
N133X0.3607Y-0.2683
N134X0.3401Y-0.2796
N135X0.3297Y-0.2962
N136X0.325Y-0.3225
N137X0.3287Y-0.3476
N138X0.3403Y-0.3643
N139X0.3612Y-0.3762
N140X0.3879Y-0.3799
N141X0.4126Y-0.3768
N142X0.4331Y-0.3649
N143X0.445Y-0.3489
N144X0.4505Y-0.3225
N145G00Z0.01
N146X0.325Y-0.3946
N147G01Z-0.005
N148X0.4503Y-0.3946
N149X0.4503Y-0.4481
N150X0.4424Y-0.4769
N151X0.4187Y-0.4878
N152X0.3944Y-0.4755
N153X0.3877Y-0.4405
N154X0.3877Y-0.3946
N155G00Z0.01
N156X0.3877Y-0.4282
N157G01Z-0.005
N158X0.3791Y-0.4525
N159X0.3537Y-0.474
N160X0.3249Y-0.4927
N161G00Z0.01
N162X0.2875Y0.3476
N163G01Z-0.005
N164X0.2875Y0.2365
N165G00Z0.01
N166X0.2875Y0.2924
N167G01Z-0.005
N168X0.1624Y0.2924
N169G00Z0.01
N170X0.2874Y0.2219
N171G01Z-0.005
N172X0.2127Y0.1742
N173X0.2874Y0.1248
N174G00Z0.01
N175X0.2127Y0.1742
N176G01Z-0.005
N177X0.1623Y0.1742
N178G00Z0.01
N179X0.1625Y0.1102
N180G01Z-0.005
N181X0.2876Y0.1102
N182X0.2876Y0.0629
N183X0.2789Y0.034
N184X0.253Y0.0215
N185X0.2289Y0.0333
N186X0.2211Y0.0629
N187X0.2211Y0.1102
N188G00Z0.01
N189X0.1629Y-0.0891
N190G01Z-0.005
N191X0.1629Y0.0069
N192X0.288Y0.0069
N193X0.288Y-0.0863
N194G00Z0.01
N195X0.2273Y0.0069
N196G01Z-0.005
N197X0.2273Y-0.0806
N198G00Z0.01
N199X0.194Y-0.1766
N200G01Z-0.005
N201X0.1729Y-0.1887
N202X0.1624Y-0.2122
N203X0.1709Y-0.2402
N204X0.1832Y-0.2488
N205X0.2024Y-0.252
N206X0.2211Y-0.2489
N207X0.2333Y-0.2403
N208X0.2421Y-0.2149
N209X0.2366Y-0.1953
N210X0.2232Y-0.1793
N211X0.2876Y-0.1915
N212X0.2876Y-0.2497
N213G00Z0.01
N214X0.2682Y-0.3449
N215G01Z-0.005
N216X0.2787Y-0.3394
N217X0.2878Y-0.3124
N218X0.2839Y-0.2947
N219X0.274Y-0.2838
N220X0.2472Y-0.2746
N221X0.2168Y-0.2734
N222X0.196Y-0.2745
N223X0.1775Y-0.282
N224X0.1673Y-0.294
N225X0.1625Y-0.3123
N226X0.1731Y-0.3381
N227X0.1992Y-0.3476
N228X0.2274Y-0.3393
N229X0.239Y-0.311
N230X0.2352Y-0.296
N231X0.2243Y-0.283
N232X0.2069Y-0.2758
N233X0.1837Y-0.2784
N234G00Z0.01
N235X0.125Y0.2907
N236G01Z-0.005
N237X0.125Y0.2055
N238X0.0962Y0.2268
N239X0.0546Y0.2483
N240X0.0267Y0.2576
N241X-0.0001Y0.2617
N242G00Z0.01
N243X-0.0058Y0.1909
N244G01Z-0.005
N245X0.0135Y0.1909
N246G00Z0.01
N247X0.1057Y0.0982
N248G01Z-0.005
N249X0.1162Y0.1037
N250X0.1253Y0.1308
N251X0.1214Y0.1485
N252X0.1115Y0.1594
N253X0.0847Y0.1686
N254X0.0543Y0.1698
N255X0.0335Y0.1687
N256X0.015Y0.1612
N257X0.0048Y0.1492
N258X0.0Y0.1309
N259X0.0106Y0.1051
N260X0.0367Y0.0956
N261X0.0649Y0.1039
N262X0.0765Y0.1321
N263X0.0727Y0.1472
N264X0.0618Y0.1602
N265X0.0444Y0.1673
N266X0.0212Y0.1648
N267G00Z0.01
N268X0.0925Y0.0809
N269G01Z-0.005
N270X0.115Y0.0703
N271X0.1249Y0.0444
N272X0.1195Y0.02
N273X0.1032Y0.0085
N274X0.0842Y0.0084
N275X0.0662Y0.0187
N276X0.0277Y0.0605
N277X0.0118Y0.0761
N278X0.0Y0.0805
N279X0.0001Y0.0043
N280G00Z0.01
N281X-0.0011Y-0.0103
N282G01Z-0.005
N283X0.124Y-0.1024
N284G00Z0.01
N285X0.124Y-0.0159
N286G01Z-0.005
N287X-0.0011Y-0.1046
N288G00Z0.01
N289X0.0292Y-0.1192
N290G01Z-0.005
N291X0.0098Y-0.1276
N292X0.0Y-0.1515
N293X0.0031Y-0.1734
N294X0.014Y-0.1879
N295X0.0318Y-0.1935
N296X0.0498Y-0.1893
N297X0.0623Y-0.1744
N298X0.0664Y-0.1525
N299X0.0755Y-0.1766
N300X0.0956Y-0.1871
N301X0.1172Y-0.1785
N302X0.1251Y-0.1529
N303X0.1144Y-0.1293
N304X0.0972Y-0.1222
N305G00Z0.01
N306X0.0252Y-0.211
N307G01Z-0.005
N308X0.0093Y-0.2181
N309X0.0003Y-0.2452
N310X0.004Y-0.2629
N311X0.014Y-0.2738
N312X0.0408Y-0.2829
N313X0.0712Y-0.2842
N314X0.092Y-0.283
N315X0.1105Y-0.2756
N316X0.1208Y-0.2636
N317X0.1253Y-0.2453
N318X0.1149Y-0.2195
N319X0.0888Y-0.21
N320X0.0606Y-0.2181
N321X0.0491Y-0.2465
N322X0.0528Y-0.2616
N323X0.0637Y-0.2746
N324X0.0811Y-0.2817
N325X0.1044Y-0.2792
N326G00Z0.2s0m05
N327X1.0Y1.5Z0.5
N329M30
maybe my post processor is putting in some junk stuff?
thanks matt
Group: DynoMotion Message: 8171 From: tmday7 Date: 8/26/2013
Dont know if this already been answered but here is some things i see with your Gcode.
Your first line or starting block of Gcode program, ..... N5G00G20G17G90G40G49G80 does not need a G00. And i prefer a starting block to look like this...
G17  (set xy plane)
G90  (absolute mode)
G40  (cancel cutter radius comp)
G49  (cancel tool len offset)
G80  (cancel canned cycle)
G91.1 (IJ relative arcs)
G20  (inch mode)
Line...N7G49 is redundant as you already cancelled Tool length Offset at first line of code.
Your pause at beginning is from this line of code at start of Gcode....
g04p4
Line.....N9G00G43Z0.5H1 , needs the G00 removed.
Line.....G94 should be before tool change.
Line....N326G00Z0.2s0m05, needs the s0m05 placed after line N326 with out the s0 command. M05 turns off spindle, so no need to tell spindle to spin 0 rpms.
At line....N12X0.4874Y0.4846Z0.1 add a G00 for rapid move
Clean up code and see what happens. :)
Troy
3 cycle start
N6m03s3800
g04p4
N7G49
N9G00G43Z0.5H1
N11G94
N13G01Z-0.005F1.0
N14X0.6125Y0.4846
N15X0.4871Y0.426
N16X0.6125Y0.3677
N17X0.4874Y0.3677
N18G00Z0.01
N19X0.6124Y0.3532
N20G01Z-0.005
N21X0.5377Y0.3055
N22X0.6124Y0.2561
N23G00Z0.01
N24X0.5377Y0.3055
N25G01Z-0.005
N26X0.4873Y0.3055
N27G00Z0.01
N28X0.5441Y0.1052
N29G01Z-0.005
N30X0.5441Y0.0561
N31X0.5082Y0.0562
N32X0.4942Y0.076
N33X0.4885Y0.1086
N34X0.4935Y0.1367
N35X0.506Y0.1539
N36X0.5276Y0.1659
N37X0.5551Y0.1685
N38X0.5808Y0.1635
N39X0.6007Y0.1491
N40X0.6112Y0.1296
N41X0.6139Y0.108
N42X0.607Y0.0798
N43X0.5965Y0.0671
N44X0.5797Y0.0574
N45G00Z0.01
N46X0.6125Y-0.0315
N47G01Z-0.005
N48X0.5341Y-0.0315
N49X0.501Y-0.0407
N50X0.4912Y-0.0547
N51X0.4876Y-0.0771
N52X0.4913Y-0.099
N53X0.5012Y-0.1132
N54X0.5341Y-0.1232
N55X0.6125Y-0.1232
N56G00Z0.01
N57X0.4874Y-0.2107
N58G01Z-0.005
N59X0.6125Y-0.2107
N60X0.4874Y-0.3045
N61X0.6125Y-0.3045
N62G00Z0.01
N63X0.5257Y-0.3921
N64G01Z-0.005
N65X0.5015Y-0.4028
N66X0.4917Y-0.4187
N67X0.487Y-0.4393
N68X0.4951Y-0.4724
N69X0.5187Y-0.4844
N70X0.5392Y-0.4765
N71X0.5487Y-0.4594
N72X0.5591Y-0.4182
N73X0.5756Y-0.3989
N74X0.5971Y-0.4017
N75X0.6086Y-0.4165
N76X0.6121Y-0.4372
N77X0.6108Y-0.4577
N78X0.5995Y-0.4741
N79X0.5798Y-0.4814
N80G00Z0.01
N81X0.45Y0.4926
N82G01Z-0.005
N83X0.45Y0.3815
N84G00Z0.01
N85X0.45Y0.4374
N86G01Z-0.005
N87X0.3249Y0.4374
N88G00Z0.01
N89X0.325Y0.3669
N90G01Z-0.005
N91X0.45Y0.3139
N92X0.325Y0.2611
N93G00Z0.01
N94X0.3683Y0.3485
N95G01Z-0.005
N96X0.3683Y0.2793
N97G00Z0.01
N98X0.451Y0.2465
N99G01Z-0.005
N100X0.3258Y0.2465
N101X0.3258Y0.1677
N102G00Z0.01
N103X0.3254Y0.0571
N104G01Z-0.005
N105X0.3254Y0.1531
N106X0.4505Y0.1531
N107X0.4505Y0.0599
N108G00Z0.01
N109X0.3898Y0.1531
N110G01Z-0.005
N111X0.3898Y0.0656
N112G00Z0.01
N113X0.3249Y0.0425
N114G01Z-0.005
N115X0.45Y0.0425
N116X0.3249Y-0.0513
N117X0.45Y-0.0513
N118G00Z0.01
N119X0.45Y-0.0659
N120G01Z-0.005
N121X0.45Y-0.177
N122G00Z0.01
N123X0.45Y-0.1211
N124G01Z-0.005
N125X0.3249Y-0.1211
N126G00Z0.01
N127X0.4505Y-0.3225
N128G01Z-0.005
N129X0.4459Y-0.2969
N130X0.4337Y-0.2796
N131X0.4137Y-0.2679
N132X0.3884Y-0.2647
N133X0.3607Y-0.2683
N134X0.3401Y-0.2796
N135X0.3297Y-0.2962
N136X0.325Y-0.3225
N137X0.3287Y-0.3476
N138X0.3403Y-0.3643
N139X0.3612Y-0.3762
N140X0.3879Y-0.3799
N141X0.4126Y-0.3768
N142X0.4331Y-0.3649
N143X0.445Y-0.3489
N144X0.4505Y-0.3225
N145G00Z0.01
N146X0.325Y-0.3946
N147G01Z-0.005
N148X0.4503Y-0.3946
N149X0.4503Y-0.4481
N150X0.4424Y-0.4769
N151X0.4187Y-0.4878
N152X0.3944Y-0.4755
N153X0.3877Y-0.4405
N154X0.3877Y-0.3946
N155G00Z0.01
N156X0.3877Y-0.4282
N157G01Z-0.005
N158X0.3791Y-0.4525
N159X0.3537Y-0.474
N160X0.3249Y-0.4927
N161G00Z0.01
N162X0.2875Y0.3476
N163G01Z-0.005
N164X0.2875Y0.2365
N165G00Z0.01
N166X0.2875Y0.2924
N167G01Z-0.005
N168X0.1624Y0.2924
N169G00Z0.01
N170X0.2874Y0.2219
N171G01Z-0.005
N172X0.2127Y0.1742
N173X0.2874Y0.1248
N174G00Z0.01
N175X0.2127Y0.1742
N176G01Z-0.005
N177X0.1623Y0.1742
N178G00Z0.01
N179X0.1625Y0.1102
N180G01Z-0.005
N181X0.2876Y0.1102
N182X0.2876Y0.0629
N183X0.2789Y0.034
N184X0.253Y0.0215
N185X0.2289Y0.0333
N186X0.2211Y0.0629
N187X0.2211Y0.1102
N188G00Z0.01
N189X0.1629Y-0.0891
N190G01Z-0.005
N191X0.1629Y0.0069
N192X0.288Y0.0069
N193X0.288Y-0.0863
N194G00Z0.01
N195X0.2273Y0.0069
N196G01Z-0.005
N197X0.2273Y-0.0806
N198G00Z0.01
N199X0.194Y-0.1766
N200G01Z-0.005
N201X0.1729Y-0.1887
N202X0.1624Y-0.2122
N203X0.1709Y-0.2402
N204X0.1832Y-0.2488
N205X0.2024Y-0.252
N206X0.2211Y-0.2489
N207X0.2333Y-0.2403
N208X0.2421Y-0.2149
N209X0.2366Y-0.1953
N210X0.2232Y-0.1793
N211X0.2876Y-0.1915
N212X0.2876Y-0.2497
N213G00Z0.01
N214X0.2682Y-0.3449
N215G01Z-0.005
N216X0.2787Y-0.3394
N217X0.2878Y-0.3124
N218X0.2839Y-0.2947
N219X0.274Y-0.2838
N220X0.2472Y-0.2746
N221X0.2168Y-0.2734
N222X0.196Y-0.2745
N223X0.1775Y-0.282
N224X0.1673Y-0.294
N225X0.1625Y-0.3123
N226X0.1731Y-0.3381
N227X0.1992Y-0.3476
N228X0.2274Y-0.3393
N229X0.239Y-0.311
N230X0.2352Y-0.296
N231X0.2243Y-0.283
N232X0.2069Y-0.2758
N233X0.1837Y-0.2784
N234G00Z0.01
N235X0.125Y0.2907
N236G01Z-0.005
N237X0.125Y0.2055
N238X0.0962Y0.2268
N239X0.0546Y0.2483
N240X0.0267Y0.2576
N241X-0.0001Y0.2617
N242G00Z0.01
N243X-0.0058Y0.1909
N244G01Z-0.005
N245X0.0135Y0.1909
N246G00Z0.01
N247X0.1057Y0.0982
N248G01Z-0.005
N249X0.1162Y0.1037
N250X0.1253Y0.1308
N251X0.1214Y0.1485
N252X0.1115Y0.1594
N253X0.0847Y0.1686
N254X0.0543Y0.1698
N255X0.0335Y0.1687
N256X0.015Y0.1612
N257X0.0048Y0.1492
N258X0.0Y0.1309
N259X0.0106Y0.1051
N260X0.0367Y0.0956
N261X0.0649Y0.1039
N262X0.0765Y0.1321
N263X0.0727Y0.1472
N264X0.0618Y0.1602
N265X0.0444Y0.1673
N266X0.0212Y0.1648
N267G00Z0.01
N268X0.0925Y0.0809
N269G01Z-0.005
N270X0.115Y0.0703
N271X0.1249Y0.0444
N272X0.1195Y0.02
N273X0.1032Y0.0085
N274X0.0842Y0.0084
N275X0.0662Y0.0187
N276X0.0277Y0.0605
N277X0.0118Y0.0761
N278X0.0Y0.0805
N279X0.0001Y0.0043
N280G00Z0.01
N282G01Z-0.005
N283X0.124Y-0.1024
N284G00Z0.01
N285X0.124Y-0.0159
N286G01Z-0.005
N288G00Z0.01
N289X0.0292Y-0.1192
N290G01Z-0.005
N291X0.0098Y-0.1276
N292X0.0Y-0.1515
N293X0.0031Y-0.1734
N294X0.014Y-0.1879
N295X0.0318Y-0.1935
N296X0.0498Y-0.1893
N297X0.0623Y-0.1744
N298X0.0664Y-0.1525
N299X0.0755Y-0.1766
N300X0.0956Y-0.1871
N301X0.1172Y-0.1785
N302X0.1251Y-0.1529
N303X0.1144Y-0.1293
N304X0.0972Y-0.1222
N305G00Z0.01
N306X0.0252Y-0.211
N307G01Z-0.005
N308X0.0093Y-0.2181
N309X0.0003Y-0.2452
N310X0.004Y-0.2629
N311X0.014Y-0.2738
N312X0.0408Y-0.2829
N313X0.0712Y-0.2842
N314X0.092Y-0.283
N315X0.1105Y-0.2756
N316X0.1208Y-0.2636
N317X0.1253Y-0.2453
N318X0.1149Y-0.2195
N319X0.0888Y-0.21
N320X0.0606Y-0.2181
N321X0.0491Y-0.2465
N322X0.0528Y-0.2616
N323X0.0637Y-0.2746
N324X0.0811Y-0.2817
N325X0.1044Y-0.2792
N326G00Z0.2s0m05
N327X1.0Y1.5Z0.5
N329M30
thanks matt
Group: DynoMotion Message: 8172 From: yeamans115 Date: 8/26/2013
the kmotion is what pauses, I have other gcode that do not have any pause to let the spindle get up to speed. they still have the scary pause at first run.
my gcodes with pause for spindle speed work like it should AFTER the scary kmotion pause.
dolphin cam does spit out some stupid stuff, I did not clean up the code before posting it....
anyways what would make the kmotion rezero the 3 axis on the first run to the last position in the code? if I catch it and rezero again it does not act abnormally.
this has no toolchanger being a knee mill
matt
Group: DynoMotion Message: 8173 From: yeamans115 Date: 8/26/2013
picture of the trajectory planner
http://imageshack.com/scaled/large/513/psb.png
Group: DynoMotion Message: 8174 From: Tom Kerekes Date: 8/26/2013
Hi Matt,
I think I was able to duplicate what you are seeing thanks for the info.  I don't understand it yet.  Please give me some time to look into it.
It seems to be related to jogging, then doing a simulate run, then a G0 with no destination specified.
Group: DynoMotion Message: 8175 From: yeamans115 Date: 8/26/2013
YYYYYYYYYYYYYYYYYYEESSSS!!!!
I am not crazy
I saw 9 full seconds on the counter before the spindle turned on tonight.
matt
Group: DynoMotion Message: 8176 From: yeamans115 Date: 8/27/2013
I got some of my post processor cleaned up and machine specific now.
I did up a simple circle to test the machine once I get back any input on the kmotion fix.
( Produced :- 10:40:03 Tuesday, August 27, 2013 )
( CNC File :- aa demo )
( Post Processor :- M_SHIZ )
( Tools Used :- )
N5G20G17G90G40G49G80
N6G00Z0.5H1
N7S1000M03
N8G04 P4.0
N9G94
N10X0.75Y0.0
N11Z0.05
N12G01Z-1.0F10.0
N13G03X0.0Y0.75I-0.75J0.0
N14X-0.75Y0.0I0.0J-0.75
N15X0.0Y-0.75I0.75J0.0
N16X0.75Y0.0I0.0J0.75
N17G00Z0.5
N18M30M05
Group: DynoMotion Message: 8178 From: Tom Kerekes Date: 8/27/2013
Hi Matt,
Please see if the latest Test Version fixes the issue.  Problem was that a Simulation Run of a Job with a dwell sometimes inserted a dwell into the beginning of the next job.  If the inserted dwell was at a different machine coordinate from the current position then the DROs (and commanded position) snapped to that position during the dwell.    This bug was introduced in V4.31d when fully buffered dwells and rapids were introduced and the Simulation Run Button.
See:
http://tech.groups.yahoo.com/group/DynoMotion/message/8177
Group: DynoMotion Message: 8179 From: yeamans115 Date: 8/27/2013
so I got the newest version loaded.
how do I get all my settings to load into the newer kmotion revision?
Group: DynoMotion Message: 8185 From: yeamans115 Date: 8/27/2013
so far it seems good.
I have to machine some stuff in the morning so I will get some fresh new g codes a run through it.
thanks matt
